We make use of favorites, and they are very helpful, but I find myself toggling favorites on and off all day to switch between those and searching for non favorites (we use a dynamic document to pull in a few thousand connections from a database). It would be awesome if you could show favorites AND search results for non favorites at the same time. Either a split navigation view, or pin the Favorites at the top somehow.
I’m looking for a way to display favorites and search results side by side, without needed to toggle favorite filter to go back and forth. I was thinking it would look something like this.
Thank you for the details. To be honest, it’s not that easy to implement with our framework as it is right now. It would take an enormous effort to restructure everything to make that even possible. I’m also pretty sure there’s a huge performance hit to iterate through all items twice to render two separate areas like this - especially when you have a lot of tree items. On another note, it doesn’t really seem to follow common design patterns. I’m afraid a UI like this will confuse the majority of users instead of being helpful.
Well, I’m not a fan of this to be honest. The search result shouldn’t show any items you didn’t search for. Right now those filters are always applied using an AND operator. I guess, what we need in this case is some sort of query language support. Something where you can type or configure:
“server100” OR “Favorite=true”.
In the dashboard you can already build filters like this but in the navigation tree it’s not possible at the moment. Maybe we can add support for something like this.
A variation of the original request. I can mark stuff as a Favourite. Is it possible to always show all favourites at the top of the navigation bar? Like a folder that just contains my favourites? Instead of selecting the Search Icon and then clicking Favourite?
just to let you know, there’s an option to always show the main filter button (incl the favorite filter) in the search box directly so that you don’t need to click the search icon. I think this makes it quick and easy to switch between favorites and all items.
Bumping this as my server list is extremely long, and currently i need to duplicate connections to have them at the top so when one of those ‘favorites’ gets updated, i have to duplicate the other version too.
The current filter is cumbersome, you have to find and click the tiny search icon and then click into it, then when i’m finished i have to go back and disable it. At least take it outside the search menu, maybe to the right as a quick access button.
