Option key doesn't work after upgrade to 3.2.1.6 (Beta)
I’ve just upgraded to Royal TSX 3.2.1.6 (Beta) and detected that Option key doesn’t work anymore.
Use case:
Speed moving in command line by pressing Option (Alt) + Left arrow and Option (Alt) + Right arrow.
Expected:
$ command option1 option2 option3
Move cursor at the end of ‘option3’ then press Option (Alt) + Left arrow. As a result you will be able to move your cursor.
Current situation:
Move cursor at the end of ‘option3’ then press Option (Alt) + Left arrow. As a result you will see ‘[D’ produced in the console,
$ command option1 option2 option3[D[D[D
Could you please have a look?
Thanks a lot in advance!
Alexey
Hi Alexey,
this should be fixed in the latest beta (3.2.1.8 and iTerm2 plugin version 3.2.1.5).
Hi Felix,
Thanks a lot! Just upgraded and can confirm from my side that the issue is fixed now.
Have a good day!
Alexey
Glad to hear that!
Have a nice weekend!
Felix
