Hello everybody,
just started to use RoyalTS and already have a question:
Is there a way to auto. open a webpage in chrome and perform a login within a RemoteDeskop? So i don’t have to open the browser/page manually?
Thanks in advance
Hello everybody,
Thanks in advance
the RDP protocol does not have any way to remotely execute commands directly. The only way to interact with the remote session is by keyboard/mouse. You could try to leverage a key sequence task but this can be fragile and potentially dangerous as it simulates keyboard input and any interaction while this task is executed can interfere and break the task.
thank you for your answer. Already played around with different key sequences. But as you said… very fragile and often enough something goes wrong. I’ll delete the sequence and open them manually ![]()
