Hi
Just found this utility and I’m very excited.
One question, I’d like to open a OpenVPN connection before accessing my servers
Is this possible?
Hi
Is this possible?
check out our connect and disconnect task feature:
https://content.royalapplications.com/Help/RoyalTS/V4/index.html?tutorials_workingwithtasks.htm
Thanks Stefan
I will look into this ASAP and advise
I’m not familiar with OpenVPN but I suppose they have some kind of command line interface which should support opening/closing of VPN sessions.
If that’s the case, you can leverage command tasks to integrate OpenVPN into your workflow and either manually open/close VPN using the task or automate it using the Connect/Disconnect task configuration of your connections.
Alternatively, if there’s an AppleScript interface for OpenVPN you can also integrate that into Royal TSX.
Please let me know if that helps!
