I have a std license, and my update settings are also std.and default. Beta updates are not checked .. but still i get Beta updates.
If that tick box to enable / disable beta updates do not have any affect, what does? How do i avoid installing beta’s ?
Hi Claus,
Royal TS may ask you to update to a new beta version by mistake. This is a bug and a fix is already available. If you don’t want to test drive the beta or have issues, please install the latest stable release build, which can be found here:
https://royalapps.com/ts/win/download
Sorry for the inconvenience caused & please let me know if that helps!
best regards,
Thank you for Quick response
.. and no I like to just have a stable version;-) sorry. No bugs to report
Cheers
Hi Claus,
sounds good.
Let me know if you need anything else, otherwise have a nice day!
best regards,
Just want to add I got the Beta today (7 Feb) when I used the Help > Check for Updates option.
Had to uninstall the Beta version. The stable download version would not install successfully over the Beta version.
