Navigation search - Keyboard shortcut
It would be great if you can add keyboard shortcut to get to navigation search box (usually ALT +O in other applications)
In our organization network engineers using RoyalTS and very happy with it so far but needing to use the mouse to get to new connection is a little bit hard.
While chasing connection, vlan , subnet … we usually need to jump between 4-10 devices which means after typing few commands I need to get my hands of keyboard to search for new connection.
Apology if the feature already there but I couldn’t find it
you can already assign a keyboard shortcut for the global search in Royal TS:
https://docs.royalapps.com/r2023/royalts/user-interface/commands.html#-global-search
Note that you may need to use deep or global scope to make it work while other connections have the input focus. Make sure you choose a shortcut which doesn’t interfere with system or other application shortcuts (if you want to change the default).
Working!! Thanks Stefan.
Great to hear that! Glad I could help.
