Several annoying websites (including Synology devices) have decided to separate the Username selection from the Password, so you type your username, then click enter, then your password.
It would be good to have a feature where you can set an “Auto-Complete” rule for a certain URL.
This would also be good for when a Session expires, and you are returned to a login page, where the URL would be recognised, and an Autofill applied.
Hi Chris,
we do work on some updates to make sure these multi step logon forms will work in the future. Not sure when we will be able to release it but just a heads up that we are working on something.
We recently released the public Beta build of Royal TS v26 (Windows), which includes a much improved auto-fill feature that was introduced in Royal TS V7.3. I believe this might help with your auto-login issue. You can find more information on this topic here: Auto Fill for Web Page Connections - Knowledge Base - Royal Apps
And you can download the new Beta build here:
