Missing features (coming from MobaXterm)
Good day,
I am working on a MacOS, coming from Windows and used MobaXterm in the past. All of our Windows users in the company still use MobaXterm but I wanted everyone to use the same software, and Royal TS I definitely prefer for just connection management and usage.
I am seeing a lot of great features in Royal TS(X) and would like to see if we can add some features, or know some easy workarounds that we are missing in Royal software.
Number 1:
One of the things is that when using Broadcast mode, in MobaXterm (there the feature is called MultiExec) we can easily exclude a single node, without disconnecting the session. I have not yet found out if and how I would be able to do this.
Number 1.5:
Also, pasting a clipboard (for example multiple commands) to all (active) broadcast I am not sure if it is working properly.
Number 1.6:
Pasting just a single session, and not to all, (if pasting to all is default)
Number 2:
We sometimes do a network and port scan from within MobaXterm to see what devices are active and what ports are open.
Number 3:
A “local” terminal (bash / shell /etc) where you can run from the local computer some things. For Windows this should include things like Bash etc.
Number 4:
Miniservices:
We use a lot of file transfer for temporary making our device available on-site on a local network, just to quickly transfer a few files (without installing a full server) For that we use the following:
Number 4.1:
TFTP Server
Number 4.2:
(S/C)FTP Server
For any of these I am looking for either a feature to be added (in form of a plugin, or build-in) or an *easy* to use workaround. Meaning, it should in the end all be available from within the Royal software.
Hi Caspar,
as for Point 1, you are able to activate the option “Broadcast Input to all Terminal Sessions” via the Context menu as shown here:
This will then be indicated by a “BROADCASTING” text in the top-right corner:
Unfortunately, it’s currently only possible to broadcast to all active terminal sessions.
As for the other points, I will move your thread to the Feature Request “Ideas” forum.
Hi Christoph,
We know that we can do broadcasting, but we want to exclude a single or multiple terminals (temporary) from the broadcast to run a single command sometimes. This is part of our workflow which can sometimes hinder us from using this.
Thank you for putting this on idea’s and I hope they might be added in the future!
Caspar
this is something that i’ve been looking for for years as well.
I was wondering if there were any of these features currently already in the pipe-line, since we are considering moving our colleagues over but for some colleagues certain features are blockers.
