maybe you can help me, I have currently encountered a problem which I can not fix myself:
Every web page is mislocated while high DPI settings are set to System (Enhanced) as recommended here:
As soon as i switch it to System the problem is solved but the application is blurred. Everything else is working fine just the web pages are affected.
Resolution: 3840x2160
Display scaling: 150% (144DPI)
“Disable display scaling on high DPI settings”: no effect if checked / unchecked
The image shows the mislocated page while System (Enhanced) is active.
