If I enable “Minimize to Notification Area” (under Other in General Options), when I connect the external connection window will not open up.
It looks like it is something to do with me using “External Window (Full Screen)” and “Use multiple monitors”
I will work okay if I use it with the connection embedded into main window or a external window that is not full screen.
Anyone having the same issue, or is it just me?
