Manage permissions for single documents using AD Groups
Currently users are able to access ALL documents in the Document Store on Royal Server if they are member of the ‘Royal Server Users’.
It would be helpful to limit access to available documents to specific Active Directory security groups. This is required to provide specifc global configurations to different teams.
Hi Peter,
this is included in our current Beta which can be found here:
Let me know if this helps,
michi
Looks good so far. I had some problems getting it to run since I did not specify any credentials for the Royal Server connection in Royal TS. I thought, it uses the current AD account to connect, but I had to specify the account to get it to work. Without credentials in the Royal TS connection, the list of documents remains empty after activating permissions.
Would be better if the Royal TS connection usese the current user accout by default for the connection.
