Disclaimer: I know, I know, beta’s are not recommended and unsupported. But I just can’t wait until September
Hi Stephan,
we absolutely know it’s exciting when new software releases, however there’s a reason why these releases are still in beta and unsupported.
Basically, you’re using an unfinished build, which comes with risks involved.
We created a knowledge-base article regarding this topic, which you can find here:
https://royalapps.com/go/kb-all-os-betas
Do you have a specific question regarding a feature which isn’t currently supported on macOS Big Sur or is there any other way we can help?
Hi Christoph,
Another question; once Monterey is released, will RoyalTSX 4 run on it?
Hi Stephan,
while we try to make Royal TS & Royal TSX run on all new operating systems, our priority is to support our latest releases.
In Royal TSX case, this would be V5.
If you want, you can test Royal TSX V4 on the latest macOS Monterey beta and see if it suits your needs.
You can download our previous releases here:
https://www.royalapps.com/go/kb-all-previousversions
