it would be nice to have a Logoff Button in the context menues like disconnect, like the tab or in the navigation bar
Hi Marius,
this is not possible unfortunately. The RDP protocol doesn’t support session logoff. If MS implements such a functionality, we will provide better access to that.
thank you for you input. But what is a bit strange to me because even the RDCMan from MS has this ability also other RDP Managers aswell.
RDCMan (and others) are using a different API to do that and it’s also kind of misleading/dangerous because they actually “reset” the session using the WTS API. There are a couple of issues with this approach:
So if you really need to “kill” the session, we recommend you use the dashboard for that. It provides more control and better context what’s really happening.
