I am trying to override the default Terminal log file name format but cannot get it to work. Is there token replacement for iTerm2 Terminal within Royal TSX, and if so, is there any documentation on it?
Will.
Will.
Hi Will,
are you trying to create the override for Royal TSX on macOS or Royal TS for Windows. I’m asking because you posted this question in the Windows forum.
My apologies. I didn’t realize I was in the Windows forum. This question was for macOS. I can post into macOS.
Cheers,
Will
No worries, I can move it there. No need to create a new one.
Hi Will,
Unfortunately there’s no way to customize the log file format at the moment. The version of iTerm2 we’re using in Royal TSX unfortunately doesn’t support that.
Felix
