LastPass Vault federated ID
Dear all,
when I try to use Federated ID with azure as identity provider, I can’t open external last pass vault.
When I am changing the user, so it’s not synchronized from Azure AD, it works.
Does anyone discover the same issue ?
Thanks in advance,
Natalie
Hi Natalie,
unfortunately, this is currently not supported by the LastPass CLI/API, as seen here:
https://github.com/lastpass/lastpass-cli/issues/519
Sorry to be the bearer of bad news!
best regards,
Christoph Mühlberger
