Lastpass connection in configure autostart documents
We use a somewhat complicated setup with four documents we always want to load:
  • a shared Royal-TS file
  • a personal Royal-TS file
  • a personal Keepass file
  • a shared Lastpass account (with personal login).
Using “Open documents from last session” works, as long as opening the lastpass accounts works. If you have problems with the internet connectivity, als lastpass fails to load, and you close Royal-TS, it doesn’t open again on startup (at least in some cases).
The option Start-and-Exit, Application Start seems to solve this with the “open a selection of documents” option. But I can’t add the lastpass connection there.
This would be a relatively easy thing to fix, I should think, (or am I missing something.).
