I’ll try to explain why do i need it. - I made the work for all the
folders and connections, and i try to mark where i’ve done work, and
where not. Green folders are done and separate connections out of the
folders should be marked also
As i see it
here’s the example
But instead of second string it could be a:
“Recently used icons” and above .. maybe 8 of them (they should most nicely fit)
