I created a SSH session using embedded PuTTY. After establishing the connection my key sequence is executed. Unfortuntately this is not working on reconnection. Is this by design or is this an error in my configuration?
Hi Tobias,
all tasks (command/key sequence) are not executed when you reconnect. This is by design. If you want to reconnect and have all tasks executed, you need to disconnect, then reconnect.
Thanks for your fast answer ![]()
You’re welcome!
