Keep tab order on "Reconnect on startup"
I’m using the same RDP connections almost every day and always sort them in a specific order.
The feature “Reconnect on startup” is great, but it re-opens the connections in random order.
It would be great, if the sort order of the tabs could be kept when closing Royal TS and the reconnect on startup feature opens them in the same order.
Hi Rene,
you’re right, the order of the stored active connections is based on the tree traversal - not the tab ordering.
I changed the logic a bit to use the tab ordering of the main window but active connections of other tabbed windows will be stored in the tree traversal order.
Hi Stefan
Sounds great to me. Thank you very much. Can’t wait for the changed behaviour :slight_smile:
René
Any timeframe when this change will be released?
I can’t tell an exact release date but my guess would be between the next 2-4 weeks. If you like, I can prepare a private build for you to test. If you do, I kindly ask you to open a support ticket referring to this topic and I will prepare a build for you.
Thanks for the offer, but it’s not needed :slight_smile:
Will re-order my tabs manually until the official release.
