I recently updated to 6.1.10216 - Beta on Windows 11. I now am experiencing an issue that seemingly happens randomly when navigating between tabs. TS just starts flashing back and forth between tabs and becomes unresponsive. I have to end the task. Is there a fix for this or is it happening to anyone else?
Hi Michael,
Can you please create a new support ticket here:
and attach a screen recording of the effect happening as well as attach debug logs, by following these steps:
- Go to Royal TS Options –> Logging
- Set “Logging Level” to “Debug”
- Enable “Save to File” to any path you want to
- Try reproducing your issue
- Disable “Save to File” option
- Attach the log file to this ticket
Thanks & best regards,
Same here on Windows 10 … for me it helps to minimize and restore the window.
Greetings
Michael
