Slothy
May 21, 2026, 11:18am
1
Is it possible to use the folder name to be the computername in connections stored in that folder.
e.g.
Foldername: Servername001.FQDN
SSH Connection: Computername pulls the Servername001.FQDN from the foldername
Webpage Connection : Computername pulls the Servername001.FQDN from the foldername
This way I can create a single folder with multiple types of connections but I am only typing the servername once.
thanks
Andy
In Royal TS V7/26 this is not possible but we do have a good story for Royal Connect in this area. There’s much more flexibility and your use case should be covered as well. Unfortunately it will still take a while until we have a beta release for Royal Connect.
Hi @stefan_koell thanks for the update. Is Royal Connect a seperate product, or will this be incorporated in to RoyalTS?
Andy
It will be a separate product but covered by our desktop license. You can find out more about Royal Connect here:
FAQs about licensing can be found here:
In short, if you have active maintenance, it will be covered.
