Integrating Edge/Chromium to replace EssentialObjects/Chromium
Have you considered integrating WebView2 in the future to replace, or in addition to, EO.WebBrowser ? Is it possible?
https://docs.microsoft.com/en-us/microsoft-edge/webview2/
yes this is something on our list to investigate. Right now, the web view 2 is still very rough and has many issues. One could say it’s far from complete. Since EO and web view 2 are both chromium based and EO is a mature and quite stable product, we will keep EO for the time being. Not sure when we have a working plugin based on web view 2 though.
Check out Royal TS Beta Release Notes - #16 by system
Edge/WebView2 replaces IE (RIP)
WebView2 seems to work fine, but looks like the option to set up auto-fill is missing (there’s just “Auto Fill” button, no Configure). I assume this’ll be added later?
Thanks for testing the beta. I just released a new version which should close those gaps. Let me know if you still see any issues.
I’ve been using the new beta for a few days, and WebView2 definitely seems to work better than Chrome (I’ve yet to have the bug where form fields stop accepting input; alert() boxes not taking over the whole application is also much more user-friendly).
Somewhat unrelated: it looks like Chrome plugin is slightly broken at least in beta 18 – a few pages that used to work now report “Too many redirects”, though I only noticed this because I hadn’t switched to the WebView2 plugin yet on my work machine – the problem only affects Chrome.
Thanks for the feedback. If you have scenarios where we should take a closer look, please open a new question here in the forums or simply open a new support ticket. I’m happy to look and see if we can improve things.
Not sure if I should open a new topic for this, but I noticed some small problems:
  • Ctrl+F toolbar remains on top when switching to other tabs
  • buttons in Web Page ribbon tab sometimes become disabled; I’m not sure what causes this, seems to happen completely randomly. I then have to switch to another tab and back and sometimes click both inside the web page and the tab before buttons become enabled again
  • a few times I had an error that the session couldn’t be created (can’t remember the exact message unfortunately, and it only happened 2 or 3 times so far), workaround was to close the Dashboard tab first
But otherwise WebView2 definitely seems to work better than Chromium – I’ve had some other glitches with it that just don’t happen any more.
thanks for the detailed report! I’ve implemented changes for all three points:
  1. Find panel: We now use WebView2’s native Find panel exclusively. Its visibility follows the browser tab, so it should no longer appear over other tabs. Browsers shown side by side can each keep their Find panel visible.
  2. Ribbon buttons: I found issues with how the active browser was tracked when focus moved into the ribbon. Background browser events could also interfere with the command state. This should now consistently target the selected browser.
  3. Session error: The dashboard preview and connection tab could share a session while requesting different browser settings. That provides a likely explanation for why closing the dashboard helped. Dashboard previews now use separate sessions, with cookies and login state isolated per connection and from connection tabs.
That last change means signing into a website in the dashboard will no longer sign you into its connection tab. Dashboard browsing data starts fresh, persists between selections unless clear-on-close is enabled, and is cleared independently.
Previews requiring a custom proxy or Secure Gateway now show an explanation and an option to open the connection, where those settings are supported.
I’d appreciate another test with these changes once we released a new version, particularly to confirm whether the session error is resolved in your setup.
Thanks.
One more wish, if possible: show an indicator that the page is loading. Chromium had a statusbar, while there doesn’t seem to be anything in WebView2 (a few of the pages I access with RoyalTS take a long time to load, and give no indication that they’re waiting for the server to respond when clicking on buttons).
Hi there!
I’ve extended the status tooltip at the bottom edge (the one that pops up when you hover over links).
Thanks again for your feedback—it really helps!
Thanks, the tooltip works well.
Another wish: when downloading files, remember the used directory (currently, even if I download multiple files in the same session, the Save dialog always opens with Downloads folder active).
Thanks for the feedback. Great idea, will put that on our backlog.
There’s still a small problem with the Find panel – while it’s hidden if I switch to a different general tab, it remains on-top if I switch to a different browser (sub)tab, or to the Downloads tab (and if I do that, and switch to a different general tab afterwards, the Find panel remains on top).
The improved download location handling and a fix for the find panel issues will be part of the next release. Stay tuned…
Here’s another wish: when a web page opens multiple tabs, and then closes them, RoyalTS focuses the first (original) tab instead of the last one (or the tab that spawned the tab that was just closed).
Eg. tab 3 was opened from tab 2, and when it’s closed, tab 2 should be focused, but RoyalTS focuses tab 1.
Thanks for the suggestion! This is fixed for the next release. Closing a browser subtab will return you to the tab that opened it. If that tab is already closed, Royal TS will activate the next tab to the right, or the one to the left if there isn’t one on the right.
Thanks.
There’s also a regression I noticed: looks like the web page doesn’t receive focus when double-clicking a connection in the tree (I’ve got some web-managed switches that have some sort of CAPTCHA on the login page, and I use the Focus action to place the cursor in the CAPTCHA input box, but this stopped working at some point, unless I click inside the web page before autofill runs).
Thanks for the report. I think I was able to fix the focus issue as well.
