Improve CSV import
at the moment its necessary to manually map the csv values CredentialMode, CredentialUser and CredentialPassword so that an import with credentials is working. This is annoying because I have to do a csv import every day. Without the manual mapping the credentials are ignored and i have to edit every imported server manually.
Please improve the csv import so that all the available csv values are mapped automatically and a manual mapping is unnecessary
Hi Peter,
if you have to do a CSV import every day, then I believe you might want to consider taking a look at the CSV import dynamic folder that can be found here: https://github.com/royalapplications/toolbox/tree/master/Dynamic%20Folder/CSV
The advantage, in this case, would be that you would only have to configure the dynamic folder once. As soon as you have done that, you can simply “reload” the dynamic folder every day to update your connections. I believe this would be the best solution for your use-case. I hope this helps!
