Import from mobaxterm .mxtsession
Can we please have a feature to import sessions from Mobaxterm? I have been using Mobaxterm for years. I have close to 100+ sessions. I just bought RoyalTS and I realized I need to create all connections from scratch.
When we export out, the file extension is *.mxtsessions. Atleast if we can scrub the data and convert that file to a CSV file. It would be helpful.
Attached is a sample file from Mobaxterm backup. Appreciate if we can get this feature sooner.
I’ve done some research and couldn’t find good documentation of the file format. It’s quite cumbersome to “reverse engineer” the data from the file and would take a huge amount of time and effort to make a full fledged importer. If you can scrub the data you need from that file you could write a simple powershell script which creates a Royal TS document for yourself.
Here’s our PowerShell docs and some sample scripts:
https://content.royalapplications.com/Help/RoyalTS/V5/index.html?scripting_gettingstarted.htm
