After a system crash RoyalTS 5 will no longer start. Well, I can start RoyalTS and the RoyalTS window will appear, but before the window is filled with connections etc. RoyalTS shuts down.
I’m assuming configuration got messed up, but I can’t find any command line parameter to tell RoyalTS to reset.
Does anyone know of a solution to this?
can you try to rename the file %appdata%\code4ward\code4ward.RoyalTS.UserPreferences.config and start Royal TS again.
If this resolves the issue, you can check this KB to find out how to restore a previous config from the backup (which Royal TS by default performs):
https://www.royalapps.com/go/kb-ts-win-restorebackup
Renaming the file didn’t help. Now the splash screen appears and then closes, and nothing else.
By the way I’ve had this issue a couple of times before. I’m pretty sure I’m not the only one (which is why I started a forum topic). My old support ticket is now gone - otherwise I would have checked that answer.
I opened a new ticket as well in case that’s faster (I cant do any work until this is resolved)…May I suggest you add a commandline parameter that resets RoyalTS to a working/default state? That would be helpful as this appears to be a recurring problem.
