How to use RoyalTS with Lastpass
Can someone assist me in understand and setting up RoyalTS with my Lastpass? The release notes say it is compatible with Lastpass Vault but I don’t know how to set it up.
Thank you in advance for your help.
check out our help chapter for LastPass:
https://content.royalapplications.com/Help/RoyalTS/V4/index.html?import_lastpass.htm
You may also check this KB:
Thank you that helped a lot. I tried searching for Lastpass but just got the solution page you referenced. I needed the first link which shows how to import it.
Thank you again, Love the software!!!
Keep up the great work!!
Glad I could help. Thanks for the kind words!
Quick note,
It isn’t accepting my username and/or password. I do have 2FA enabled for my lastpass via yubikey and/or google authenticator.
When I put in my username/password the credential screen disappears and returns. It doesn’t say it was invalid.
Can you look in LastPass in the log if the login attempt was successful? To further troubleshoot your issue, I suggest you open a ticket instead of using this thread.
Sure. I can open a ticket.
Thank you
Those links seem to be broken.
Could you please help provide updated links?
Thanks.
I think the link you are looking for is this one:
https://docs.royalapps.com/r2023/royalts/advanced/index.html#open-a-lastpass-vault
