How to see where a session already exists?
the filter for displaying just open sessions is very useful, but is there any option to scan the entry’s if there is an open session after a client restart? As an old session with expired password could cause also a locked account it is useful twice.
Best regards
I’m not sure I completely understand your question. Royal TS V4 prompts you with the option to re-open all previously connected sessions if you close Royal TS while sessions are open. Are you referring to that feature?
I didn’t get this prompt. May because my connections are saved in a password protected .rtsz which I have to open first?
You’re right, the feature only works if you configure the auto start documents in View -> Options -> General:
https://content.royalapplications.com/Help/RoyalTS/V4/index.html?reference_options_general.htm
Works perfect! Thank you very much!
Glad to hear that!
