How to connect to Exchange Online with Powershell
Dear all,
I try to connect to Exchange Online with Powershell and found the same question including the solution here:
Question: PowerShell Connection Settings (Exchange Online) - Questions / Royal TS (for Windows) - Royal Apps
Solution: Integrate PowerShell in Royal TS | Royal Apps
Either I don’t get the solution or it does not work any more (written for Royal TS V2).
Could anybody give me a hint how to realize the connection?
For example the open Powershell-Console does not show up in the dashboard. So I have no possibility to make the AdHoc connection with my
Also I would like to make use of Powershell V7 within RoyalTS. Is it possible to change the used version within the application?
Regards
Hi Dan,
If you want to do this, I am afraid you will need to integrate the PowerShell in Royal TS, since the PowerShell plugin in Royal TS is not designed for your use case. You can find out how to do that here:
If that doesn’t help, I would ask that you elaborate on your issue and open up a ticket here: Open Ticket | My Royal Apps
Kind regards,
Germar
