How open session to localhost (local shell)
I’ve been searching the forum en support site for a couple of days trying to find an answer for what I want.
I’m running Royal TSX on my macbook and I would like to be able to open a connection to my local shell. Without logging on to other servers. Just running it locally.
But till now I was not able to get this working.
Does anybody know how to do this.
Thx.
Hi Martijn,
it’s pretty easy:
  • Create a new “Terminal Connection”
  • In the properties, set its “Connection Type” to “Custom Terminal”
Hope that helps!
Yep. That’s what I was looking for! Thanks!
Glad I could help, Martijn! =)
