I like RoyalTSX. Nice tool to work with.
Here’re some improvements, which can make it even better.
In split mode i have 8 (left side) and 10 tabs (right side). Being in terminal window on left side tab group if i press ctrl+option+tab i get switched to right tab group, which is fine.
If i now press again ctrl+option+tab (being on right tab group), then cursor jumps to Ad-Hoc drop down on the toolbar. More pressing ctrl+option+tab just adds “tabs” to ad hoc “computer name” field.
Would be logical, that “ctrl+option+tab” combination just cycles between split tabs. And then inside tab you cycle with ctrl+tab between different terminal windows (this currently works as it should).
P.s. And i’m aware of “Select Previous Tab Group” option, but all extra clicks in the menu makes user experience bad. And 4-key shortcut for “Select Previous Tab Group” is not convenient at all.
Any ideas/thoughts on that?
