Feature Request: Snap Window to Common RDP Display Sizes
An odd quirk of modern RDP is that it seems to still “prefer” standard display sizes (WXGA, etc.). At least when connecting to Windows servers, if the RoyalTSx window isn’t exactly a common display size, there’ll be letterboxing around the session. Once connected, you can resize the window a smidge or reconnect the session and RDP will adapt to whatever window size you have, but that initial connect having letterboxing is annoying, especially if you’ve just connected to a whole folder’s worth of sessions.
Maybe offer the Terminal-like ability to resize the window in “whole” increments while a key is held? Or add a menu option “resize connection area to…” with an editable list of common resolution options?
