Royal TS
Right mouse click on RDP-connection and have the possibility to make connection with are without gateway settings.
Royal TS
Hi Frederik,
are you referring to the Remote Desktop Gateway or the Secure Gateway (SSH tunnel)?
Right click RDP object > Connect with Options > Connect through Gateway > select from list, including “No Gateway”
This is a nice idea, but its just as easy to do with Modifiers - Ive configured mine to disable the RD Gateway when holding Alt and connecting.
