Description:
In the connection window of Royal TSX on macOS, the split pane divider between the server list (left sidebar) and the active session (right pane) can sometimes be accidentally moved — especially when trying to copy text from a PowerShell session. If the mouse slightly misses the text and hits the divider, the layout shifts unintentionally.
Feature Suggestion:
Please add an option to lock or fix the position of the divider — either via the context menu or in the application settings. Ideally, this should be a toggleable setting in case users still want the flexibility to move it manually.
Benefit:
Improves usability and prevents accidental interface disruptions during regular use.
