Feature Request: Logging Variable
Please can we add a variable within the logging name to support the “Display name” as well as the “Hostname” (&H) something like &N or enable Token replacement within this field so we can use %Name%
This would be very very helpful!
Hi Richard,
thank you for the feedback. I’m assuming you are referring to the tokens for the PuTTY based plugin. I’ve implemented the standard replacement token resolution for the log file name property. So you can now use tokens like $Name$, $Description$, $CustomField1$, etc. in the file name entry box. The next 4.2 beta release will have that on board.
That’s exactly what I’m looking for. Thanks!
