Feature Request: Connect multiple system directly from system list
Hi Team,
I would really like it to select/connect multiple systems at once directly from the system list. ATM it’s only possible to connect whole folders.
The function I’m asking is already implemented inside the Dashboard but I need this directly inside the system list.
BR
David
Hi David,
I’m not 100% sure what you mean by “system list”. I am assuming you mean the tree in the Navigation panel. If so, there’s unfortunately no way to select multiple items in the tree, so the only way is to either use the folder or the dashboard view to select individual connection - as you pointed already out.
