When Royal TS first opens: please add an option to default to auto-reconnect each time without the prompt to reconnect.
It would be great if every time that Royal TS opens, it would just auto-reconnect. I can imagine some situations where the prompt could be useful, but for me the prompt is only an unnecessary annoyance – but if I turn off the prompt then it doesn’t reconnect at all, so I can’t get rid of the prompt.
Hello Royal-TS Team. It has now been 9 months, since Aaron asked here. Can you give us please a little feedback on this request?
A “no - won’t be implemented” is imho better than no feedback at all..
Greetings, I am also strongly interested in auto-reconnect feature.
I fixed the reconnect part with having a Disconnect Task which has a timeout and then reconnects with
Command: C:\Windows\System32\cmd.exe
Arguments: "/c Timeout /T 30 && RoyalTS.exe /action:connect /donotactivate /protocol:rdp /using:uri /uri:$URI$"
Working Dir: C:\Program Files (x86)\code4ward.net\Royal TS V4
