Feature req: prominently display filenames loaded when starting royal ts
when opening royalTS,
i have 2-3 settings files that are loaded,
it would be nice to have the filename displayed with a larger font,
it takes a few seconds to for you eye to find the file in question
the next version will show the file name in the dialog title bar prominently. I guess this makes it even easier to see for which file the password should be entered. You can test the current beta and see the result:
https://www.royalapps.com/go/kb-ts-win-downloadbeta
