Extend Royal TS with Connection Broker integration/query
For better usability for IT deparments who own larger RDS deployments with several collections and stages it would be very helpful if Royal TS can query information directly from the connection broker(s) about the deployment settings, Collections and their settings as well as all RDSH which belong to the collections and show the servers accordingly as RDP Connection or other remote connection options.
This would help to replace the limitations of server manager and be a simple alternative.
regards
Andreas Vierthaler
Hi Andreas,
thank you for the feature request. Sounds interesting. Can you provide some links to docs or even better PowerShell scripts which demonstrates what kind of information and functionality you are looking for?
quite simply get the data from the following queries into Royal TS. This will make it easier for admins to maintain controll of their environments, especially in private clouds used to host the RDS environment with a forget and deploy design.
get-rdsessioncollection
get-rdsessioncollectionconfiguration
get-rdsessionhost
get-rdremoteapp
get-rdremotedesktop
set-rdsessioncollectionconfiguration
etc.
regards
Andreas
This would be awesome.
