I noticed that the font settings under “Options → User Interface → Font” seem to affect only the Navigation pane.
Would it be possible to extend this setting to the entire user interface, or at least to the fields shown in the Properties tab?
Maybe I’m missing a setting somewhere, but I couldn’t find any option to change the font used there.
One practical use case is when credentials need to be read manually and typed on another device, such as a smartphone, where copy-paste is not available. In those situations, character readability becomes important.
I know that Royal TS offers the option to avoid ambiguous characters when generating passwords, but that only helps for newly generated passwords. Existing passwords, usernames, hostnames, custom fields, and other manually entered values can still contain ambiguous characters.
For this reason, I think it would be great if the configured custom font could also be applied to the Properties view, or if there were a dedicated option to use a monospace font for protected fields and other credential-related fields.
