Export SSH connection with credentials
Using RoyalTS v6.1 I would like to export ssh connections in a csv file with credentials properties tab.
Is it possible ?
Thanks in advance.
Franck.
Hi Franck!
you can use the Data ribbon tab to export connections to CSV (including credentials). Just select the document and go to Data:
