Hi. Would it be possible to have an option to enable the key task sequence to run on reconnect for an RDP connection? Thanks.
Hi Olivier,
right now, reconnect will not execute any tasks (command or key sequence tasks). If you want to have those executed as well, simply disconnect and connect again. I’m hesitant to create an extra option for this since it only takes one more click (the next button in the toolbar).
