Installing the new 6.0 version and Eset detected virus within? suspect its a false positive?
downloaded from https://download.royalapps.com/RoyalTS/RoyalTSInstaller_6.00.50609.0.msi
Hi Kevin,
yes, this seems to be a false positive from ESET. You can find the MSI Virus Total report here:
Hi everyone,
we’ve received a number of tickets from various customers who have been notified that the latest version of Royal TS contains an unwanted file (Malware). This is a false-positive detection and, unfortunately, has to be addressed by ESET.
You can find the Virustotal scan reports for all Royal TS V6 builds here:
https://community.chocolatey.org/packages/royalts-v6
In the meantime, you can downgrade to the previous version and report this to ESET.
All previous versions of Royal TS, can be found here:
https://www.royalapps.com/go/kb-ts-win-previousversions
Sorry for the inconvenience this has caused!
best regards,
Christoph Mühlberger
To add to Christoph’s response: you can find the current Virus Total report here:
We just received the following message by ESET:
‘It is a false positive of our scanner and this issue will be fixed in the next update of detection engine.’
best regards,
