End and home keys instead of ctrl+end and ctrl+home at the navigation pane
Is it possible to change? It’s more regular to move from begin to end and back with “home” and “end” keys.
I’m not really able to prevent the CTRL+HOME and CTRL+END behavior of the tree as it’s part of a 3rd party component library but I was able to add the same behavior when you press HOME and END. So in the end, the tree will do the same in both cases.
I was also able to improve the keyboard navigation in the grid views (dashboard) using Home and End.
Thanks again for the feedback!
