we recently started using Royal TS 7, and in IT we use YubiKeys for authentication. I imported our servers into Royal TS via the VMware plugin and now want to enable smart card redirection for all servers. How can I do that?
Some colleagues also add RDP connections manually, and for each one they have to enable smart card redirection separately. I’d like to enforce this setting for all RDP connections by default. How can I do that?
Hi Kai,
this can be done by editing the Default Settings for the Remote Desktop Connection Type via the “Application” Document and activating the Smart Card Redirection there:
For existing objects, you can use the bulk-edit feature to edit all connections at once. Please refer to the following links:
