We have some troubles with session settings on internal webbrowser. So we tried the Royal Passwords Extension and it works good for us. Sadly there is no option to get MFA running thru the Extension.
Pls make MFA possible for Royal Passwords Extension (Chrome+Edge on Windows 11).
KR Robert
Hi Robert,
if you setup auto fill for your web site requiring an MFA code, you could configure it using the $MfaCode$ token and use it from the extension as well.
The Autofill with MFA works in Royal TS, but i don’t get an possibility to enter an MFA in Royal Password (Chrome Extension) when i try to open a website thru pulldown menu.
To clarify: is the TOTP code generated in Royal TS or is it prompted? The latter is not supported by the browser extension at the moment.
The code promted.
Would be nice to implement this feature in royal passwords!
I’m not sure if we can implement that and I honestly don’t think it makes much sense. I mean, what’s the difference to enter the MFA code directly in the web form after all the other fields have been automatically filled compared to entering the MFA code in a “separate” form and let it automatically fill everything? Not sure I understand the use case here.
When i open the Website thru Pulldown, the credentials instantly get put in and also the login butten will be pressen like in the internal browser. i’ve no change to put in the mfa code in a field.
In internal browser i get questioned about the mfa and the effektive password (eg. $value-$mfacode) is put into the field.
Credential:
Website:
In external Browser Chrome i don’t get the MFA Promt so the credentials are not correct
I will investigate if this is something we can handle/implement from the browser extension.
