Dynamic Folders Python Libraries
I am on Royal TSX (for macOS) version 6.1 and trying to run Python script using 3rd party libraries e.g boto3 in dynamic folder. However for libraries installed via pip/pip3 (installed globally) getting following error.
“ModuleNotFoundError: No module named ‘XXXXX’”
Python installed via homebrew and on the path.
How can I use pip packages in dynamic folder script?
Version 6.1.0.1000Version 6.1.0.1000
Hi Mohacs,
can you please make sure the following settings are configured within the “Royal TSX Settings > Advanced > Dynamic Folder” section:
Furthermore, please make sure that the Python version is set to “Python 3”:
In case the issue persists, please create a new support ticket via the following link, so we can assist you in this matter:
@Christoph thank you for your reply. They settings are exactly the same, I have submitted a support ticket.
