I’m trying to test dynamic folders.
In the parent folder, I put custom fields that I propagate throughout my tree structure.
I’m trying to use these custom fields in ComputerName field but no success.
Moreover, the $EffectiveUsername$ token simply disappears when loading.
Could you help me correct my file?
The file ![]()
"Objects": [
"Type": "Folder",
"Name": "Folder Level 1",
"Properties": {
"CustomField1": "abc"
"Objects": [
"Type": "Folder",
"Name": "Folder Level 2",
"Properties": {
"CustomField1FromParent": true
"Objects": [
"Type": "Folder",
"Name": "Folder Level 3",
"Properties": {
"CustomField1FromParent": true,
"CustomField2": "def"
"Objects": [
"Type": "Folder",
"Name": "Folder Level 4",
"IconName" : "Database",
"Properties": {
"CustomField2FromParent": true
"Objects": [
"Type": "Folder",
"Name": "Folder Level 5",
"Color" : "#3C925C",
"Properties": {
"CustomField2FromParent": true,
"CustomField3": "gh"
"Objects": [
"Type": "TerminalConnection",
"TerminalConnectionType": "SSH",
"Name": "[$CustomField1$$CustomField2$$CustomField3$@] - PostGre - vm01(ssh)",
"ComputerName": "$EffectiveUsername$@$CustomField1$$CustomField2$$CustomField3$@vm01@host",
"Properties": {
"KeepAliveInterval" : "60",
"SOKeepAliveOption" : true,
"PuttyLogFileFlushFrequently": true,
"PuttyLogging" : "1",
"RecordCreateSubDir": true,
"RecorderOutputPath" : "C://Local//Logs",
"RecordStartOnConnect" : true,
"CustomField3FromParent": true
Hi Yann,
could you please open a ticket regarding this issue? You can do so via the following link: Open Ticket | My Royal Apps
Done ! ![]()
