Dynamic Folder loading crash/slow to load
I have a dynamic folder that pulls from a JSON file directly (instead of generating via royalTS itself) as a method to try and avoid this issue as I have had in the past when running dynamic folder scripts.
When reloading a dynamic folder it is really slow/application stops responding. I am talking several minutes at least. In My example it is pulling in a 2.8mb JSON of machiens in an OU. It makes no difference if that JSON is on the local host or network. I am running version 6.0.0.6
Any help appreciated.
Hi Charlie,
can you provide a json file for us to test? Make sure no sensitive information is included and feel free to open a support ticket in case you don’t want to share it publicly.
Hi - will send via support ticket
Submitted. Will update here for anyone else watching.
