Dynamic folder cache is cleared if script fails
It would be nice if there was a way to make it so that, if you have
folder persistence checked and the refresh fails, it doesn’t clear the folder’s
cache?
Currently, if you have “Automatically reload folder contents” checked and the script fails (i.e. network/VPN not available) the folder’s contents if cleared even if the “Persist (cache) folder contents” is checked.
