Is this application capable of handling a 2FA prompt from Duo on SSH sessions? I don’t see any way of responding to the prompt, and the terminal doesn’t display until you’re logged in to the system.
Am I missing something?
we successfully tested Duo and Google Auth 2FA with SSH, so this should work. Can you provide more details about your setup? What plugin are you using (PuTTY or Rebex)? What version of Royal TS are you using? Can you provide some screenshots what you see and describe what you expect?
If you don’t want to share screenshots publicly, feel free to open a support ticket and continue a private conversation: https://www.royalapps.com/go/support-ticket-new
